Ana içeriğe geç
The Dell Latitude E5550 is a 15-inch business laptop. It was first released in late 2014 with a 4th-generation Intel processor and subsequently updated in early 2015 with a 5th-generation Intel processor.
My laptop won't turn on without being plugged in
I recently got this laptop, but I can't get to turn it on without the power chord being plugged in.
I've tried out several options, but nothing seems to work.
Here's the battery report from windows
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
The battery report should contain info about the Design Capacity value (in mAH) and the Full Charge capacity value (in mAH).
You don't say what "several options" you've tried, but since there a no values for these parameters in the battery report, either the battery is faulty or perhaps there's a driver problem.
Go to Device Manager > Batteries > right click on Microsoft ACPI-Compliant Control Method Battery > uninstall and follow the prompts.
Restart the laptop and allow Windows to reinstall the driver. Allow the battery to charge for a while (does the laptop indicate that the battery is charging, you never said?) then create another battery report and check.
If still nothing is shown for these values, replace the battery and check.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
John Gonzalez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 133
