Ana içeriğe geç
Bu, 2010 yılında piyasaya sürülen ve VCVRA-1003 model numarasından tanımlanabilen bir HP Deskjet 1000 yazıcıdır.
not communicating with my computer
the computer keeps saying there is an error with the printer, i tried to reinstall the printer and it and now it can't find it. the printer turns on the paper is fine and there is a new ink cartridge. seems like the computer and the printer are not communicating
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Hi,
What is the make and model number of the computer and what operating system is installed?
Have you checked that the printer cable is securely connected to the printer and the computer?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
If your computer is not communicating with your HP Deskjet 1000 printer, there are several steps you can take to troubleshoot the issue:
  1. Check the connections: Make sure that the USB cable connecting the printer to the computer is securely plugged in on both ends. Try unplugging and replugging the cable to ensure a good connection.
  2. Restart both the printer and the computer: Sometimes simply restarting the devices can resolve communication issues.
  3. Check for driver updates: Go to the HP website and check for any available driver updates for your printer. Download and install any updates that are available.
  4. Uninstall and reinstall the printer: Go to the Control Panel on your computer and select "Devices and Printers." Right-click on the HP Deskjet 1000 and select "Remove Device." Then, reinstall the printer using the installation CD that came with it, or download the drivers from the HP website and install them manually.
  5. Try a different USB port: If the USB port that you are currently using is not working, try plugging the printer into a different USB port on your computer.
  6. Check for hardware issues: If none of the above steps work, there may be a hardware issue with either the printer or the computer's USB port. Try connecting the printer to a different computer to see if it works. If it does not, there may be an issue with the printer itself and it may need to be repaired or replaced.
Note that these are just some general troubleshooting tips and the specific steps may vary depending on your operating system and printer model. It's always a good idea to consult the user manual or contact HP customer support for further assistance.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
amy bean sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 639
