Ana içeriğe geç
Corsair Gaming K70, profesyonel düzeyde bir görünüm ve his için eloksallı, fırçalanmış alüminyum gövdeye sahip, tam mekanik bir oyuncu klavyesidir.
How to replace the volume nob
I broke the volume not on my corsair k70 mk2 and while I had it I found it really useful but I can't find a replacement part online and it is really bugging me because I dont want to have to buy a complete new keyboard
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
Hello, i'have the same problem, did you find a remplacement wheel ?
Thanks !
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There is a screw under the trim ring on the side of the volume wheel. If you take off all of the keys to see the screws to take off the backplate, there is one that is not easily seen as you need to pry that silver trim ring off the right side and there is the last screw under there. From there, replacement of the wheel is pretty simple.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I simply sprayed with a electronic cleaner foam and blew out with air and wiped off wheel and its solved all my scrolling skipping issues and got it back to excellent accuracy, if the scrolling is functional, but the accuracy is messed up.
tarafından
Yorum Ekle
Yanıtını ekle
Healer WR sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 61
Her zaman: 1,728
