Ana içeriğe geç
Epson EcoTank L3150 Wi-Fi All-in-One Ink Tank Printer
20 Soru Tümünü görüntüle
Printer does not print in color even after cleaning
Hello,
I have an Epson L3110 and for some weeks the color printing was getting weaker and weaker.
I followed youtube and cleaned the print head using isopropanol and warm distilled water. After cleaning, there was no blockage to water flowing through the printhead ... everything seemed great. After putting the printhead back in, I did nozzle cleaning 4x to make sure the printhead was loaded with color ... and the color printing was OK!
I turned the printed off for the night and the next day, printing in color resulted in nothing being printed, only black printing worked! I cleaned the head again, did 5x nozzle cleaning to fill the printhead with color, I made sure there is no air in the tubes and when printing in color .. nothing happenned, I still cannot print anything in color.
What am I doing wrong?
Best,
Daniel
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 14
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If your printer isn't printing in color even after performing cleaning 1-855-324-7676 there could be several underlying reasons first check if the ink cartridges are not empty or low on color ink. Sometimes a color cartridge may still be full but a clog or malfunction can prevent the ink from flowing properly.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hi There - I had to go one beyond the Nozzle Cleaning and do a Power Cleaning to get mine sorted.
You can access it by right clicking your printer in control panel/devices and printers and selecting Printing Preferences, then Maintenance tab at the top and then Power Cleaning.
You can only do this once every 12 hours and it uses a lot of ink and also puts that ink into the ink pads, but if you are only doing it once in a blue moon, you should be good to go.
Anyway, worked for me - good luck.
Puan 0
1 Yorum:
Hi!
I did that twice unfortunately without effect. I ordered a bunch of cleaning fluid, will unclog the whole thing again making sure there are no hardened clumps in the tubing, cartidges and tank system and if that doesnt help, Im gonna say goodbye to my printer:)
Thanks for responding, I appreciate it.
Daniel
tarafından
Yorum Ekle
Just for info, for this printer type.
Beware when you use cleaner fluid/injecting your tank manually, sometimes it goes to the flexy cable that point to the head and guess what happened.
  1. It could make your printer regulator death (death printer)
  2. It could make your printer controller defect (some only can print in black and some none of the colour were printed)
Puan 0
Yorum Ekle
black ink nahi a rahi
Puan 0
Yorum Ekle
COMPLETION ANSWER: POOR QUALITY OVERALL ANSWERS
First, FOR THE LOVE OF WHATEVER DEITY YOU BELIEVE IN (if you do), DO NOT POWER FLUSH YOUR PRINTER! You will destroy your waste ink pad!!! This shouldn't be an option on the printers with the non-serviceable pad! It's fine on the printers with the serviceable waste pad as it doesn't kill the printer (but will not let you print). For the unserviceable units, it's a death sentence. It should have stayed in the service mode unless the pad can be user replaced.
With that out of the way, it's usually air in the lines from the ink tanks or a head clog. If it has white lines between the prints, it's likely air in the CISS assembly. If it's consistent, it usually comes down to being clogged heads. Take the printer apart and do two things:
  • Get a set of syringes (like this) and try to pull 1-2ml of ink from the dummy carts - this could fix it. Not always, but you might get lucky. DO NOT REUSE THIS INK!
  • If needed, manually clean the machine with a cleaner for Epson printheads. Some people disassemble the printers (and I have done it before), but the way Epson engineers the heads inside these printers makes that option impractical unless you are willing to risk breaking your printer. To clear the heads out, inject the cleaner inside the printhead and let it sit for ~24 hours; some take more time, some less; others do not have a set time, like the Inket Mall kit (which is priced more for professional models and prosumer wide format, it doesn't make sense for your average Epson ET- series like this). NOTE: ALWAYS drain the air from the lines from the dummy carts as this will risk getting air in the head and make it worse. See the first solution for the ones you need. DISCARD THE INK you pull - it could end up having air in it! DO NOT REUSE IT!
    To take these apart, get something you can use as a prop rod, lift the control panel out and then remove the two screws. Use said prop rod to avoid having the top fall since Epson doesn't have a rod built into the scanner on these printers.
Puan 0
Yorum Ekle
Yanıtını ekle
eubie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 34
Son 7 gün: 286
Son 30 gün: 864
Her zaman: 11,756
