Ana içeriğe geç
20 Eylül 2019'da piyasaya sürülen, isteğe bağlı hücresel bağlantı özelliğine sahip Apple'ın beşinci nesil akıllı saati.
Touch not working after screen replacement
I replaced the screen on my 40mm iWatch Series 5 and the screen shows everything correctly post repair, but I cannot get the screen to respond to my touch at all and can't get past the security code.
While repairing I wasn't sure if I had damaged the force touch sensor gasket, so I tried to install a new one. I was not at all confident of that part of the repair. The kit came with the force touch gasket sensor and a couple of the adhesive seals for either side of the gasket. The repair video doesn't go into any detail about how to apply these and after I had put one of the adhesive layers down on the cleaned case bottom rim, then the force gasket, then another layer of adhesive and finally the screen, it didn't seem to fit very snugly in the case and appeared to be riding a little bit above it. I can easily open the case with a fingernail after the repair, so pretty sure there is too much between the case bottom and the screen.
Does anyone have clearer instructions for replacing the force touch sensor and related adhesive?
Also is there any information on the three connectors from the motherboard to the display? The middle one on mine under a loupe looks a little sketchy. Could that be another reason the touch screen is no longer responding correctly for me?
Thanks in advance,
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Well check out this video it might help you out: https://www.youtube.com/watch?v=TW7flbtw...
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
thanks for the reply. Pretty sure the problem started when I replaced the glass, so none of the solutions in the video apply. I don't necessarily want to unpair because I can't do anything on the watch itself, so the phone is the only connection to the watch at this time.
tarafından
Yorum Ekle
I'm having the same issue with 2 different 40mm AWS5, did you manage to solve it? Both screens work on other AW. Is it possible that I damaged the touch IC? Can it be replaced?
Puan 0
1 Yorum:
se puede reemplazar el tactil, tengo el mismo problema, no da touch, cambie el main y sigue igual, estoy buscando un jumper
tarafından
Yorum Ekle
Yanıtını ekle
danieljseta sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 1,478
