How to reformat SSD
how to reformat external ssd
Bu iyi bir soru mu?
Open launchpad, click the "Other" folder and select "Disk Utility" (in the red box in the attached image),
and choose your external drive from the sidebar. Then, from the top bar, select erase. It will pull up a window with numerous options. If you just plan to use it for storage, just leave everything at the defaults and click erase. A pop up will appear asking you if you are sure. Tell its to go ahead and erase. It'll load for a minute or two and then, Presto! Your disk is erased!
Bu yanıt yardımcı oldu mu?
disconnect and other storage devices, and try factory reset.
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 1,542
