Ana içeriğe geç
The fourth version of Sony's famous Walkman cassette player, the WM-4 was introduced in 1983.
10 Soru Tümünü görüntüle
Tape won't spin. Please help!
I purchased this Walkman off of eBay recently, and in the description it claimed that the Walkman wouldn't work with batteries, but instead would work while plugged in. When I received it, I tried batteries and the indicator light turned on and it sounds like the belt is spinning inside of it but the tape that I'm using (good condition) isn't playing. I noticed the little nubs inside of it aren't rotating. The belt itself is something I looked at and it looks a tiny bit stretched so I ordered some new ones and they arrive tomorrow, but I was curious if it isn't the belt at all and instead is another problem. Can anyone help? This is my first time doing this sort of thing and I was super excited about trying a Walkman out for the first time.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
@arze77 this "wouldn't work with batteries, but instead would work while plugged in" would not be related to the belt but with the power circuit. Most likely a break in the connection from teh battery case. You would need to check that out. This "little nubs inside of it aren't rotating." can be the belt but again it will be the same for battery and AC adapter. If it works one way but not the other, it is not the belt.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Replace the belt. I'm surprised the old one didn't come apart with age to be honest. I did one and it was rotten. Belts need friction to work and if the old one has lost its elasticity it will slip causing your issue.
Puan 0
Yorum Ekle
Yanıtını ekle
arze77 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 527
