Ana içeriğe geç
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Restarting so much time.
Hi , i have a old computer but try to starting so much time, pc not opening just open and close not see a profile page. And i m shut down pc and open repeatly.
Pc give me a notfication is translate for english:
Start panic medi
A third party kernel extension was preventing the machine from booting successfully. All third party kernel extensions are disabled. You can re-enable them in Security & Privacy system preferences when used
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
First, try a PRAM reset. To do this, shut down the computer, then power it on while holding P + R + Option + Command on the keyboard until you hear two distinct chimes. If this doesn't help, then try to boot into Safe Mode. To do so, shut down the computer, then power it on while holding the Shift key. Continue to hold the key until you see the progress bar. Then release the key and see if you are able to boot up and login. If so, login and try to apply any available OS updates. If this doesn't help, you may have a deeper issue and may need some type of hardware repair.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
SH ZG sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 165
