Ana içeriğe geç
Repair information and support for walk-behind lawn mowers made by the Toro Company.
Front wheels not straight
On the toro 30” time master are the wheels supposed to look as they are leaning outwards and not straight? We haven’t even used ours yet , unloaded it yesterday and just want to make sure the front wheels are right before using it. Thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Since it is new, it is possible that the bolts holding the wheels in are loose. In the center of the wheels, there should be a screw or bolt that needs to be tightened. If there is no bolt visible, look closer, as there may be a cover to keep grass out.
It is worth noting that I don’t have this exact model lawnmower, but most are pretty similar in design, so please take this with a grain of salt.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Will definitely check that, thanks
tarafından
Yorum Ekle
Yanıtını ekle
Amanda Chandler sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 186
