Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Soru Tümünü görüntüle
After DIY glass/LCD repair white horizontal lines have appeared?
I just finished replacing my glass/ lcd on my iphone 3gs. I feel that I followed the youtube directions to a tee but when I turned it on the screen had its normal picture of my apps in the background but it now has a white translucent color with white stripes on the foreground. I don't know if I did something wrong or if my glass/ lcd screen I purchased is faulty. Can anyone shed any light on this? I have also unplugged and replugged the 1, 2, and 3 ribbons.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Good chance that it is defective, OR you caused some damage to the LCD when you were removing/disassembling the screen. Are there any hotspots or discoloration on the LCD while the display is off?
Bu yanıt yardımcı oldu mu?
Puan 2
7 Yorum:
There are no hotspots or discoloration except the overall faded look. What do you mean by display?
tarafından
By display I mean the capability on whether the LCD can show a picture. If there is no visible damage to the display (imagine the phone off) then it probably is a defective LCD. Get another one and test.
tarafından
thanks. They sent me another one so I hope that is the problem.
tarafından
If I was able to help, please click accept answer on the left. Thanks.
tarafından
I replaced the glass/digitizer not the lcd. So I just ordered the lcd screen and will change it out and see if that is the problem. Thanks.
tarafından
2 tane daha yorum göster
Yorum Ekle
chack the connector\flat cable might have torn-up or either the lightning prossesor need to be replaced
Puan 0
5 Yorum:
bambook2, which part do you consider the lightning processor?
tarafından
the one that goes on before the thunder??
tarafından
lol I think he means lighting processor, which I'm not entirely sure I know what that is either.
tarafından
its a physical part on the circuit board i will need to find the schematics for the iphone 3gs to help so give some time...
tarafından
The backlight circuit consist of the 6R8 coil and the 3gs backlight IC 109B
tarafından
Yorum Ekle
hii sir..i have the same problem ...there is line on the lower scree n of my iphone 4... and like a thunder...how to fix i sir? the other part of lcd on my iphone is black now...
anyone can help me?
sir if u see this my post.. can u tell me how to fix it?
kevin delmendo is my name tnx...
Puan 0
Yorum Ekle
Yanıtını ekle
Jessica sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,381
