Ana içeriğe geç
A gaming control system including a steering wheel and pedal assembly, compatible with PS2 and PC, released on November 4, 2005.
Where to find a new potentiometer?
My wheel is an FGT Rumble 3-in1. The wheel will not center on calibration and driving is erratic. I believe the potentiometer is bad, but I am not sure. I would like to replace the whole board and potentiometer, but I cannot get through to Thrusmaster at all. Nor can i find the part. Any ideas?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you remove the pot, you'll be able to measure its resistance OR its value will be written on it as it will be a 'standard' value.
Once you have that you then have to do a little more measuring. I suspect it will be a linear value (where at half a turn its value is half, at 3/4 turn its value is 3/4) but it may be a logarithmic (or audio) taper if the values you measures are not as I've said.
Once it's out, then simply google search on sites like Farnells or RS Components and it'll show up so you can order & replace. FWIW, I'd spend good money on one (def not the cheapest) as they take a lot of pounding.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
After some research, I think I found a replacement model of the potentiometer that is used in the wheel. It's called F10KV. The closest one that I could find was on AliExpress 5pcs for approximately €7 including shipping to Germany is this one.
Haven't tried it yet, but I'll give it a shot soon.
Puan 0
Yorum Ekle
Yanıtını ekle
David Calhoun sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 323
