Ana içeriğe geç
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
Boots from battery, not from power cord
I rescued the machine in question from being tossed in a dumpster. It will power up if I charge its battery in my own 17" PowerBook first. But it will not start up without the battery when I plug the power cord in, nor will it charge the battery. The power adapter I tried is the original that came with my (identical model) 17" PowerBook. I'm thinking the DC-in board needs replacing.
Bu iyi bir soru mu?
Puan 1
1 Yorum
That is what I would recommend trying first.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
That's a very good guess. I'd do it.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I concur with the others here, this is the part you need.
Puan 2
Yorum Ekle
The DC/In Board is a good place to start, but what power adapter do you have? is it a 65W or a 45W, if it's a 45W, the PowerBook can only charge off of it, and not actually run, the 65W can run, and charge at the same time.
Puan 1
2 Yorum:
The adapter is 65W. It came with my 17" PowerBook G4 1.67 GHz low-res, which is the exact same as the one that I salvaged. The salvaged PowerBook neither powers up nor charges with the power adapter. Nothing happens at all. Only an externally-charged battery brings it to life. Which, frankly, surprised me.
tarafından
You could check the connections to the DC-In board, and if that doesn't work, your best bet would be to replace it, if that doesn't do it, then the logic board, or battery might be defective.
tarafından
Yorum Ekle
Yanıtını ekle
fletcherism sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 2,142
