How to check for continuity in power button?
As title says I want to check for continuity but am not sure how.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The best way to isolate if the button is not working is to use the power pads Using MacBook Pro 2013 2014 2015 power pads if the system responds then the keyboard switch is damaged and you likely need a new keyboard assembly.
Here’s a deep dive into how the button works Macbook Pro Retina bad power button but every other key works!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 91
What are you encountering now? A bit more info would help.
DanJ tarafından
Power button doesn’t work, replaced trackpad fully thinking that was the issue it wasn’t.
asdas sdasdsa tarafından
