Ana içeriğe geç
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
371 Soru Tümünü görüntüle
How do I bring back my save data from my SD card after replacing board
Hi there, I'm replacing my New 3DS XL motherboard after breaking the original one. I wonder if it's possible to bring back your SD card data back after replacing the board. Is it gone forever or is it possible to bring it back? I have CFW downloaded on it just to let you know.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
All the data on your sd is encrypted to your original motherboard, so unless you have or can get the keys to decrypt it, it's gone. If you had CFW on your old board, you can probably get your saves back. This thread has a guide on it, but I do have a few things to add:
  • Your boot9.bin and movable.sed might already be in your luma/backups folder if you didn't delete or overwrite them. If you hacked your new motherboard with your old card though, they're most likely overwritten
  • DO NOT use the movable.sed you got from bruteforce movable. If you do, you could brick your console
  • You probably already have Checkpoint, so if you want you can use that to restore your saves instead of JKSM.
  • boot9.bin is the same for every 3ds console, so if you don't have it, you can easily dump it from your new mb
  • If you don't have your old movable.sed but you do have your old essential.exefs, you can extract your movable.sed from that with ninfs
  • You can get title IDs from 3dsdb.com
If you need any more help, don't hesitate to ask. Good luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
not really since the motherboard its self is hacked you CAN NOT just expect to swap the motherboard it WILL NOT WORK you have to rehack it since there is homebrew on the system memory you would have to hack it again then swap the .sav files over once youve gotten all the games redownloaded
Puan 0
2 Yorum:
if only it were that simple. all the saves are encrypted, so without the consoles movable.sed, those saves are gone. It is possible to recover them, but the bot won't let me explain how
tarafından
Ah thx for the knowledge
tarafından
Yorum Ekle
Yanıtını ekle
Aidan Vue sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 54
Her zaman: 599
