Need help removing bottom panel from Orion VHS player
Hi, I'm attempting to remove the bottom from an Orion VHS player, manufactured in 1998. The player eats tapes, so I would like to see if I can replace belts and the idler, if in fact i can find replacement parts for this unit. I've included a picture of the bottom panel with the important sections letter labeled.
I've removed the screws from the top that go through the motherboard into the back panel, labeled G and H. The problem is, when I depress the two tabs, C and D, the go down a bit, but don't release the back. They are still depressed in after using a small flat head screwdriver. But the panel won't budge as I try to push it downward.
I've also lifted tabs A and B to get them above the round projections. What am I doing wrong. Update: having another look at the unit, it appears the front face panel needs to be removed first before being able to remove the bottom panel.
Bu iyi bir soru mu?
2 Yorum
@lyess do you have a model number for the Orion?
oldturkey03 tarafından
@oldturkey03
Hi oldturkey,
The model is VR0210. My friend has two, this model that eats tapes, and a VR0419 which the eject button doesn't work. I managed to buy a used one from a thrift store for ten bucks that is model VR0421 that works. I bought it in case I can't fix these other two, or for parts. Thanks for your time, it's appreciated.
Lyees tarafından
