My left joystick is stuck plz help
my left joystick is stuck plz help i dropped it 1 day a go its will not go down
Bu iyi bir soru mu?
Bu iyi bir soru mu?
the stick seems broken and stuck so you will need too get it repaired
Bu yanıt yardımcı oldu mu?
not sure if this applies to the switch lite, but I've found some joysticks get stuck if you push them too far. Try gently wiggling it and it might pop back into place
If it is stuck by a foreign object, remove the case and remove it. If not, the joystick may be broken. Just replace it
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 81
