Ana içeriğe geç
The Atari Flashback 2 is the second generation of the Flashback series of the retro gaming console, the “Atari 2600”. This second-generation model was released in 2005.
I need a converter of some sort
My Atari flash back 2 turns on but will not work on my smart tv. Do I need a converter?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It depends on what kind of video inputs your smart TV has available. The Flashback 2 has the original yellow composite video output and a separate audio output, mono in this case so there's only one white connector instead of a white and a red connector like there would be with stereo output.
So you'll need to check the back of your TV to see if it has a set of three plugs together that are yellow, white and red. If not, then you'll probably need a composite video to HDMI adapter. I'm sure you can find them all over the place, but here's one of the first ones I ran across on Amazon.
Amazon.com: ABLEWE RCA to HDMI,AV to HDMI Converter, 1080P Mini RCA Composite CVBS Video Audio Converter Adapter Supporting PAL/NTSC for TV/PC/ PS3/ STB/Xbox VHS/VCR/Blue-Ray DVD Players : Everything Else
Plug your Flashback 2 into that, then run an HDMI cable from there to your TV and you should be all set.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I have Atari 2 flashback hooked up 2022 40 inch Phillips 1080 with the cable's that came with tv av cable with 3 red white yellow don't use red it is working fine.
Puan 0
Yorum Ekle
Yanıtını ekle
kittykatkorn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 1,183
