Ana içeriğe geç
Repair information for graphic tablets. Graphic tablets are also known as digitizers, drawing tablets, drawing pads, digital drawing tablets, pen tablets, or digital artboards.
20 Soru Tümünü görüntüle
Why is my laptop shutingdown immediately it turns on it shuts down
I was running my laptop on ld player but it shutoff immediately after i opened the app what is the cause
If its gpu thermal shutdown.i have waited for it to cool but does the same thing
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
It is possible that the cause of your laptop shutting down immediately after opening an app on LDPlayer is due to GPU thermal shutdown. This occurs when the temperature of the GPU (graphics processing unit) reaches a critical level, causing the system to shut down as a safety measure to prevent damage.
If you have waited for the system to cool down and the issue persists, it is likely that the thermal paste on your GPU needs to be replaced. Over time, thermal paste can dry out and lose its effectiveness in dissipating heat, causing the GPU to overheat.
To fix this issue, you can follow these steps:
  1. Turn off your laptop and unplug it from the power source.
  2. Remove the back cover of your laptop to access the GPU.
  3. Carefully remove the old thermal paste from the GPU using a clean cloth or cotton swab and isopropyl alcohol.
  4. Apply a small amount of new thermal paste to the center of the GPU.
  5. Replace the back cover of your laptop and screw it in place.
  6. Turn on your laptop and check if the issue has been resolved.
If the issue persists after replacing the thermal paste, it is recommended to seek professional help or contact the manufacturer for further assistance.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Let me try i will tell you if it worked
tarafından
Yorum Ekle
Yanıtını ekle
richard mwangi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 81
