Ana içeriğe geç
How to repair my psp when can't on power
my psp 1000 can't on and when my battery full also can't working....
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 8
3 Yorum
I have the same problem too!!
I checked the batery, the power is connected to the motherboard.
tarafından
How do I do that
that
tarafından
i have problem with my psp start and l buttom
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Look at the DC port on the PSP. Does it have the little metal pin sticking out of the middle? It is also possible that the switch on the power board may no longer work. Pick any of the guides listed on here PSP 1000 and open the PSP up and see if you can hold the power board still, plug it in and try flipping the black switch to see if it'll turn on that way. Of course there is also the possibility that your power fuse is blown and that you have an interrupted circuit. check on here for much more info about that. Hope this helps, good luck.
Resim
Bu yanıt yardımcı oldu mu?
Puan 7
7 Yorum:
i will try it....thank for teching....
tarafından
but me is 3006 modal...can help??
tarafından
ginz.. this is the guide for you PSP 300x, I'm not sure that the fuse is in the same spot..If you need further help then please start a new question.
tarafından
where the 300x fuse and i think board spot...
tarafından
uuuum...Does this work on Non-Sony PSP...cause my PSP is not sony
tarafından
2 tane daha yorum göster
Yorum Ekle
check the batery and the power on button.
Puan 2
Yorum Ekle
I had seen on Youtube if you repeatedly push up the power button, it might turn on. Worth trying
Puan 1
Yorum Ekle
Yanıtını ekle
ginz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 57
Her zaman: 38,482
