What makes the pully drive teeth to wear?
What makes the pully drive teeth to wear and cause a clicking noise while the washer agitates?
Bu iyi bir soru mu?
İptal Et
A collection of guides and support to help with washer repair.
İtibar: 1
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz AtınSprocket wear can be caused by a number of things:
- dirt/debris damaging the teeth
- Improper pulley tension
- Worn chain or belt
- Bad bearings (causing high resistance)
If you make the repair on your washer, I would highly recommend replacing as many parts in the pulley line as possible and giving everything a quick clean and lube.
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 368
