Ana içeriğe geç
Kasım 2020'de piyasaya sürülen 13" MacBook Pro, Apple'ın 8 çekirdekli CPU ve 8 çekirdekli GPU'ya sahip Arm tabanlı M1 SoC'sini içerir. (Model A2338 / EMC 3578, iki adet Thunderbolt 3 bağlantı noktası ile)
Service Recommended: MacBook Pro m1
Hello! I just changed the battery of my macbook pro m1 and I get that error. I have restored the MacBook and nothing. The battery seems to work since without the power cable it works fine, however I can't see the percentage and I get that error. Can somebody help me?
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Where did you get the battery? Also are you sure you needed to replace it? This is a young system which shouldn’t need a new battery yet.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
When you go to System Settings -> Battery, what do you see? Can you see the percentage there? If so, you should let the battery charge to around 100%, then let it discharge to around 10% or so, then reconnect the charger and let it charge up again to 100% to see if the message goes away after putting the battery through a full charge cycle. You could also try booting into Safe Mode to see if this fixes the issue. In the worst case scenario, there may be a defect with the battery you installed. Good luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Borja 1 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 464
