Why does my laptop not turn on and only the led blinks
It does not make any kind of beep, you only hear the noise of the disc and the fan
Update (04/09/23)
II fixed it but now I get this error message
help plis
Bu iyi bir soru mu?
help plis
Bu iyi bir soru mu?
Sadly the discrete GeForce 8600M GPU has failed. You’ll need to replace the logic board, consider the cost and your needs MacBook Pro 15" Core 2 Duo Models A1226 & A1260 Motherboards
It maybe time to get a newer system (used or even new) most of the software you are using here won’t run on the newer systems macOS’s (need 64bit apps Vs what you have which are 32bit)
Bu yanıt yardımcı oldu mu?
and if instead of replacing I do a reflow
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 76
2 Yorum
@rodrigorod45489 just out of curiosity, How did you "fix it" so that you got to the point of the second video?
oldturkey03 tarafından
I don't know, I disassembled the entire laptop and reassembled it
Rodrigo Rodríguez García tarafından
