Ana içeriğe geç
Cardo Systems motosiklet bluetooth kulaklıkları: Packtalk, Smartpack, Packtalk Bold ve Packtalk Black
Replacement USB connector P/N on PCB?
As with many other users I have a Packtalk Bold out of warranty with a bad USB connector. It works if the cable is held pressed up or down. Many have had solder failures but not this one, I need a new connector but studying images and footprints at Mouser and DigiKey has failed to ID a likely candidate.
Bu iyi bir soru mu?
Puan 2
6 Yorum
Did anybody ever find a solution to this problem
tarafından
The YouTube link shows someone doing it, not someone willing to share the P/N.
tarafından
Meh. My question is, “what is the part number of the usb socket?” The YouTube video and poster refuses to share his secret.
tarafından
1 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
you can find the correct USB connector here....warning...its a bit tricky without the right equipment. I have successfully fixed two so far with USB replacements. If the trace has pulled away from the board....you may need to fix that also. https://www.amazon.com/gp/product/B00NQB...
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank you I bought a couple of these off Amazon from your link from uxcell and had my local “iKrack” micro solder shop replace one for me. It worked well.
tarafından
Yorum Ekle
En Yararlı Yanıt
Resim
is standard micro usb, but many Times on this model is the PCB lines missing, then need make jumper.
Puan 2
Yorum Ekle
There is a good Youtube video on this process: https://www.youtube.com/watch?v=FLr-Keiv...
Puan 0
Yorum Ekle
Yanıtını ekle
David kelly sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 58
Her zaman: 1,941
