New 3ds shuts down after pressing L
Pressing L button on my new 3ds causes it to shut down with a poping sound
I read it might be the speaker ribbon but im not sure if it may be damaged
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi!
A 3DS that turns off with a pop means that there is a bad connection either with the speakers or the top screen. And both ribbon cables for those two parts pass right below the L button, so if pressing the button makes the system turn off, then there's definitely a bad contact in that area.
Unfortunately, there is no way to know precisely which part is faulty without opening the console and inspecting the area closely, but from what you're telling us i can see three possible sources of the problem:
Let's hope it's not the latter, because while replacing the screen or the speakers is doable with patience, replacing a connector on the board is impossible without solid knowledge and experience in micro soldering.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 82
