Ana içeriğe geç
Nintendo tarafından Switch sistemi için üretilen, kablosuz ve daha geleneksel bir video oyunu kontrolcüsü. Model numarası: HAC-013.
Left stick double clicks and gets stuck
My pro controller (2017) has a problem with its left stick that seems to double click when pressed down to the right. The right stick doesn’t do this. After opening it up, I noticed that the left stick has a loose part in the module that the right one doesn’t.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Thank you for this, I realised I had the same issue, glue didn’t hold so I use a small thin elastic band and wrapped it around the area to hold the loose part in place and now it no longer sticks:)
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Eventually it's gonna fall off, but luckily it hasn't yet so gluing it into back into place should be easier. Use a small amount of a strong glue to put it back in position, if you don't want to replace the whole joystick. You can use your working joystick as a reference for where exactly it should be.
Puan 0
Yorum Ekle
Yanıtını ekle
Juexis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 1,169
