Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
781 Soru Tümünü görüntüle
My ps3 wont spin disks. how do I know what to replace?
i got a faulty ps3 for cheap and everything's fine except when i try to play disks. they get accepted and the icon shows up but they wont show up on the ps3. i dont know whether i need to replace the lazer or the motor. any help?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It's most likely the laser that is faulty but to replace the whole drive is much easier especially if you don't have to much experience. Either way it is a relatively straight forward job, lots of videos online and most likely tutorials on this site. You can buy the drive as a complete kit online, you just need to swap the board at the bottom of your faulty drive to the new drive.
Also to note, if the warranty stickers have been removed then there is the possibility that the drive board I referred to above has already been swapped out and the one installed isn't the original and therefore even if the laser was replaced it all wouldn't play a disc.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
It maybe that the laser diode has faded and needs replacing, but other methods may get the optical pickup working again. Try removing and replacing the ribbon cable at the optical pickup (laser) end (I've seen this work). Or try adjusting the miniature potentiometer(s) a fraction in either direction and put the dial back to exactly the same position (better still, measure the resistance so you get it precise). Could use a drop of electrical contact cleaner. (I have heard this works but never tried it)
Puan 0
Yorum Ekle
Yanıtını ekle
kian hughes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 32
