Ana içeriğe geç
Motorola Droid 2 (A955), Verizon'un Droid serisindeki beşinci telefondur.
T. 5.5 Torx striped
I ordered your large fixit kit with all the torx and such but when following exact directions in removing the 5.5 Torx screws from this droid 2 (Global) they started to strip the 5 is way to small to start I went to a 6 torx and was able to remove three.. Any hints to remove these other stripped screws? I am about to just drill them out.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check out the answer here for some suggestions on stripped screw removal. If you go the route of power tools just be sure to be careful and steady so you don't damage any surrounding components. Good luck and I hope this helps.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
John McGrath sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 1,139
