Ana içeriğe geç
26 Ekim 2018 tarihinde piyasaya sürüldü. Modeller: A1984, A2105, A2106, A2108. GSM veya CDMA / eSIM, nano-SIM veya çift SIM seçenekleriyle; 64, 128 veya 256 GB depolama kapasitesiyle; Siyah, Beyaz, Mavi, Sarı, Mercan veya Kırmızı renk seçenekleriyle sunulmuştur. ("iPhone 10 R" şeklinde okunur.)
iPhone XR VDD Main Short
iPhone XR came in being stuck in DFU mode, supposedly water damage, I have opened the phone and inside was no traces of water damage ( I have checked under the shields also), tried unplugging each individual connector still same, at last I flashed the phone through 3uTools it went good without any error codes, after the flash I tought the phone will boot but it went completly dead, not drawing any current, I have checked VDD main line and it's shorted to the GND, tried injecting voltage but nothing is heating up, looked up under the microscope everything seems good, I have reballed the PMIC(after I removed it the short was still present) I'm all out of ideas and thinking of doing a swap
Bu iyi bir soru mu?
Puan 0
1 Yorum
If it is not drawing any Amps you do not have a VDD main short.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
hello there,
look at the vdd-main line diagram (you need a schematic). Start by removing the power supply bridge (R3303). This will solve a lot of your problems. In general, the line is quite straight as like for Apple and you should have no trouble finding the short (use the TP0540 test pad). Anyway, you have got dwo diferent sub-circuits of power supply: The North with all system supplied and The South - just charger with pp_bat and i2c services for main battery. Thats all. More similar casesys you can find on my (free of charge) repair blog. Just read, ask if not understanding and learn. Details can find "about me" tab.
-fingers crossing,
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
I removed R3303 and the short was gone, but out of pure frustration I already desoldered CPU, NAND and other paired components 🤦
tarafından
Did you replace it?
tarafından
Hey, it's not a matter of replacing the r3303 alone. It's just a combination of two cooperating sub-systems. Temporary removing it from the environment allows you to narrow the search area only to the passive or active side of powering.
tarafından
Yorum Ekle
Yanıtını ekle
Em4N sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 34
Her zaman: 844
