Ana içeriğe geç
GameCube, Nintendo'nun dördüncü oyun konsolu sistemidir. Onarımı basittir ve yalnızca yaygın tamir aletleri gerektirir.
Disc will stop spinning
My discs will initially start and load up, I can play for a few minutes. Then the disc will stop spinning during game play. I’ve tried cleaning the lens to no avail. Curious if this sounds like a fixable issue? Has happened with multiple games.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Rather than typing them all out again, this thread has a number of potential solutions to the issue you are having, hope this helps!
Disc not spinning in GameCube
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
This is a very common problem with all disc drives, the disc motor bearings get a tiny bit tight and it doesn't rotate at sufficient speed to recognise the disc, trying adding a tiny, very tiny! bit of oil to the disc motor bearing and see if it works
Puan 0
Yorum Ekle
Yanıtını ekle
M Doe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 699
