HP Pavilion dv6z 300 LEDs and fan turn on, display is completely black
I've been having trouble with my display for a few months now. It will occasionally decide not to turn on. Today it will not turn on at all. Everything is in perfect condition otherwise. I've tried reinstalling the RAM, Hard Drive, doing a hard reset, ect. I've seen similar HP models that have the same problem. I'm considering taking it apart and checking all the connections to the display. Any advice? Thanks ahead of time!
I have also noticed the caps lock key blinks too and the hard drive indicator is static
Update: I disassembled the whole thing and made sure the connections were okay, reseated the Processor, et cetera, with the same result. At this point not knowing whether it's the CPU or the motherboard, I don't think I'm going to go any further. It's gonna cost me more than it's worth. Thanks anyway for the help.
R. I. P. My PC.
Bu iyi bir soru mu?
7 Yorum
Does it make any noise when you press the startup button?
Owen Cunneely tarafından
I can hear the fan, and the disk drive if I happen to have a DVD in.
Marc Bizal tarafından
Have you tried an external monitor? Check the answers on this question Why does power go off immediately after turning it on? and see if that will help you out. Good Luck.
oldturkey03 tarafından
Thank you. I might try that. I've also noticed that the caps lock light is blinking, and other lights that should be showing the status of a device (i. e. hard disk) are instead static.
Marcus Bizal, let us know what you find. I keep wondering if you are running into the GPU error....
2 tane daha yorum göster
