Ana içeriğe geç
Bilgisayarınızın onarım sorularına çözüm bulun.
145 Soru Tümünü görüntüle
usb ports in front charging but no data transfer
Intel nuc7i5, windows 10. The ports don't work under the bios or OS, but able to use for charging.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Have you checked that the connectors are connected correctly? There might be a typo in the manual. Google the pinout and make sure the D+ and D- connections are right. Maybe the internal cable was mislabelled. Try leaving the V+ and GND where they are, and swapping the D+ and D- connections (If it's the kind of cable with separate connectors). Failing that, just try replacing the internal cable that goes from the USB port to the motherboard..
It might even be the cable you're using from the computer to the device. Some are wired as charging cables only and don't even have the data wires. I have a few that I had to label because they can charge but can't actually connect any devices.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
They both used to work with the cables I'm using now and then suddenly stopped. Will check under the hood. Thanks for your reply.
tarafından
Yorum Ekle
Yanıtını ekle
Leenaud sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 255
