Ana içeriğe geç
Released April 2022, Identified by model number XT2203-1.
Bluetooth and Gps troubles after screen replacement.
Hi,
i replaced my screen and housing on my Motorola edge 30 recently and everything went smoothly. But now i have trouble with Bluetooth having bad range, it is skipping/lagging a lot and has trouble connecting. Similarly the GPS has very bad accuracy.
After looking it up it seems to be the antenna that perhaps was damaged during the repair, could this be correct?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It seems like you already know the answer, and that sounds about right.
Just to be safe, I would probably check the connector and make sure it is fully plugged in, as this could also be causing the problems that you are having.
I believe that should fix the problem.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thank you very much! I will try resetting the connectors again just to make sure!
Do you know where the Bluetooth antenna is located on the edge 30, if i were to buy a replacement? Is it one of the surface mounted ones on the motherboard cover?
Picture of motherboard cover (this is the cover of edge 2022 but it looks the same), step 15
Motorola Edge (2022) Front Camera Replacement
tarafından
I am not sure, but I bet that you can Google it to find it or look in the teardown for the device.
I don't own a Motorola so I can't look, sorry.
Glad I was able to hopefully help though!
tarafından
Yorum Ekle
Yanıtını ekle
Elias Forsgren sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 376
