Ana içeriğe geç
Singer EZ-Stitch Zincir Dikiş Makinesi, yeni başlayanların kendi eğlenceli ve yaratıcı projelerini oluşturmalarına yardımcı olmak için tasarlanmıştır. El sanatları, kıyafetler, yastıklar, aksesuarlar ve daha fazlasını birleştirmek için kullanılabilir.
How to remove the needle
How do I replace the needle. My model had a plastic needle protector with no screw. How do I remove this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
hello Shauna
To remove the needle from the Singer EZ-Stitch Chainstitch Sewing Machine, follow these steps:
  1. Unplug the machine and remove the needle plate by unscrewing the screws that hold it in place.
  2. Loosen the needle clamp screw by turning it counterclockwise using a small screwdriver or the included screwdriver that came with the machine.
  3. Once the needle clamp screw is loose, carefully pull the needle out of the clamp. Be sure to note the orientation of the needle so that you can insert the new needle correctly.
To replace the needle on the Singer EZ-Stitch Chainstitch Sewing Machine, follow these steps:
  1. Make sure that the machine is unplugged and that the needle clamp screw is loose.
  2. Insert the new needle into the clamp, making sure that it is facing the correct direction.
  3. Tighten the needle clamp screw by turning it clockwise using a small screwdriver or the included screwdriver that came with the machine.
  4. Replace the needle plate by screwing it back into place.
If your model has a plastic needle protector with no screw, you can remove it by gently pulling it straight out from the machine. Once the protector is removed, you can follow the above steps to replace or remove the needle as needed.
or
you can refer to this video
link:- https://youtu.be/K11bofV8Ov0
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Shauna sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 610
