Ana içeriğe geç
Western Digital (WD) Katı Hal Sürücüsü (SSD) 2.5” 7mm ve M.2 2280 modelleri mevcuttur 120GB veya 240GB
The ssd is not showing up
The SSD is not showing up when connected to my PC. It has a lot of data in it. I had used it for transferring data. But now it is not showing up when connected to the pc. No drive is found.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
SSD card not showing in my PC. The SSD card is ok or not ok. Pls advice. What to do? What is the solution
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Well The BIOS will not detect a SSD if the data cable is damaged or the connection is incorrect. Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
but it can detect my other SSD
tarafından
Yorum Ekle
Yanıtını ekle
thrippakulath unnikrishnan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 55
Her zaman: 1,948
