Ana içeriğe geç
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Backlight died on my MacBook Pro Retina 15" mid-2012
Hi all,
My MacBook Pro Retina 15" mid-2012 "died" the other day while I was using it. Or so I thought, until I shone a flashlight through the Apple logo and I saw that the screen was working fine -- just the backlight was dead.
I tried to connect it to an projector, but that didn't work -- could it be that the GPU is dead, not just the backlight? I have a model with an Nvidia GPU and switchable graphics.
Interestingly, I left it for dead for a few weeks, then decided to open it. I didn't do much -- dedusted, pressed on one of the screen cable connectors, then disconnected the battery for 2 minutes and connected it back.
Eureka, it worked again! Backlight and all! (Didn't test connecting to a projector). But then, maybe a day later, it broke again, screen works but backlight doesn't (and again didn't check if connecting a projector works or not).
Some more info:
  • 2 years ago it fell ~15 cm (6 inches), and one of the fans started to make noise. It's still noisy but the laptop has been working fine for 2 years.
  • On the day the backlight died the first time, the table was wet. I put it on the wet table around noon. It worked until ~10pm that night, then the backlight died.
  • None of the water damage detectors inside were colored.
I'm fine with leaving it for dead, but the fact that it came back to life for a day makes me think there might be an easy fix. Is there anything that comes to mind?
Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Sounds like there is possibly a lose component inside that is sometimes making a connection...or corrosion has impacted the circuitry. It would need someone to examine the board under a microscope with voltage testing equipment to see if any component has come lose or the solder has cracked etc.....
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
alxlive sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 101
