Ana içeriğe geç
The Oculus Quest is the first standalone virtual reality headset that supports 6DOF tracking with cameras located on the headset itself. The Oculus Quest headset was released in May 2019 in 64 GB and 128 GB models.
20 Soru Tümünü görüntüle
Can I replace the charging port?
The charging port on my headset is broken and i was wondering if i could replace it somehow on my own
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You might be able to. Or at least replace the cable the charge port is on. I found a fairly thorough teardown of the device and it looks to me like the charge port is part of a flex cable which also carries signals from whatever other minor boards or components are on that side of the headset to the main board.
It looks like a bit of work, but doable if you can find a replacement part.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Blake T Francis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 525
