Ana içeriğe geç
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
401 Soru Tümünü görüntüle
Why does my MacBook wont start up anymore.
Problem with MacBook starting up with battery which requires maintenance. MacBook kept on working until after two weeks after the first warning it wont power up again after a few days
MacBook involved is an Air series mid 2012-2017.
So what we tried.
-MacBook wont power on
-MacBook also wont charge
-However, a bit later we found out the MacBook does seem to charge when first connecting MagSafe to similar other (working) MacBook and then connecting the MagSafe to MacBook which won’t start up
-MagSafe then lights up; even says it charging the battery
-When clicking the on button after a few hours of ‘charging’ with green light on MagSafe, the MacBook started up ones with sound, but not video other than black screen and then no response at all anymore
-trying some more things with MacBook, e.i. Switching battery of working MacBook in not working MacBook
-Then MacBook started up again (now for 2nd time since ‘dead symptoms’). This time even with screen working!, system was initializing, but crashed (shut of) a few seconds after logging in
-after that no more response, no start up sound, no screen life signs. Tried SMC reset and other commands against but nothing seems to work.
Ordered a new battery but since the working battery from the other MacBook also doesn’t seem to help, would this be the solution?
Also read something about the trackpad connector being a reason for the MacBook not starting up again after the first initialization. Would it be this or something else ?
Any help is appreciated, thanks in advance !
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This sounds like a dual problem!
Given the systems age you are in need of a new battery unless you’ve replaced it in the last few years.
This also appears to be deeper issue within the logic board. By chance do you remember having a liquid spill or during COVID tended to wipe down your system frequently with wet naps or spraying the case/screen with a cleaner and then wiping it down. The cleaner can find it’s way in too.
At this point you’ll need follow this guide to pull the logic board so you can visually inspect it for corrosion and any damaged components. MacBook Air 13" Early 2015 Logic Board Replacement the 2015 guide is exactly the same as yours.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Laurens E. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 30
