Ana içeriğe geç
10. nesil Apple iPad için onarım kılavuzları, söküm ve sorun giderme bilgileri; 64 veya 256 GB depolama seçenekleriyle Wi-Fi ve hücresel modelleri mevcuttur. Ekim 2022'de piyasaya sürülmüştür. A2696, A2757, A2777 veya A3162 model numaralarıyla tanımlanır.
Heating issue/screen brightness effected
Could it be possible to give me the dimensions of where the logic board is so I can place some heatsinks to try and keep ipad cooler so the screen don't keep reducing brightness. I'm sure it's a heat issue as once temperature is reduce the brightness of screen returns to normal.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here's a picture of the iPad 10 without the screen. I've marked out the logic board in the picture; basically if you cool the right edge of the iPad that's where the heat is going to be coming from.
Resim
The picture is oriented so you'd be looking at it with the charging port on the bottom.
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
cheers. Planning to use akasa double-sided thermal conductive tape. I have plenty of small chipset blue heatsinks that should help handle the heat. Poor cooling design on expensive device. Apple solution is to close down apps to reduce processor usage which bring down heat.
tarafından Paylaş
@robmods you might want to consider using a 0.3 mm Copper Shim Thermal Pads and some Kapton Tape with your heatsinks. Typically these are used for copper modding graphics cards, but I'm willing to bet that they would work really well in your iPad.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Robmods sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 540
