Ana içeriğe geç
PlayStation 3 Slim, orijinal model numarası CECH-2000 olan PS3 video oyun konsolunun ikinci sürümüdür. Sony Computer Entertainment tarafından üretilmiştir ve orijinal (Fat) Playstation 3'ün birçok sorununu gidermiştir. Ürün 1 Eylül 2009 tarihinde piyasaya sürülmüştür.
Why is my pa3 not recognizing disks?
When putting in a disk it pulls it in normally but then keeps pulling it in the same way it would if you took the disk out after touching the sensor inside the reader. After it's done overly sucking it in the ps3 doesn't recognize the disk.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
  1. Dirty or faulty disc drive sensor: The sensor inside the disc drive that detects the presence of a disc may be dirty or malfunctioning. Try cleaning the sensor with compressed air or a soft, lint-free cloth. Be gentle and avoid applying excessive pressure.
  2. Disc loading mechanism issue: There might be a problem with the loading mechanism that pulls the disc into the drive. It could be misaligned or worn out. In this case, you may need to have the disc drive repaired or replaced by a professional technician.
  3. Firmware or software issue: Occasionally, firmware or software glitches can cause disc recognition problems. Ensure that your PS3 is running the latest system software version. You can try updating the firmware or performing a system restore to see if it resolves the issue.
  4. Disc format or condition: Make sure that the discs you are inserting are compatible with the PS3 and are in good condition. Scratched or damaged discs may not be recognized properly. Try using different discs or cleaning the discs if they are dirty.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Conner Heidecker sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 97
