Ana içeriğe geç
20 Eylül 2019'da piyasaya sürülen, isteğe bağlı hücresel bağlantı özelliğine sahip Apple'ın beşinci nesil akıllı saati.
Best Non OEM Replacement Screen?
Subject is an Apple Series 5, 40 MM watch with a cracked screen. I can still see the icons.
Do I need anything more than a replacement screen kit to fix this?
There are multiple screen kits available ranging from $10 to over $200. Which is the best bang for the buck. It doesn't make sense to buy a $139 screen kit for a watch that old.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
you should link the one you're interested in so we can take a look at it.
tarafından
Looking at this one Apple 5-40mm
tarafından
@stanleybunch this isn't a full display, its only the digitizer and front glass, so if you have LCD problems, or problems with the backlight, this won't fix it unfortunately :(
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
@stanleybunch - That link is only the crystal/digitizer part it’s not the OLED panel part which is glued to the crystal/digitizer part. That’s why it’s so cheap (note they called it an LCD which it’s not)
I really don’t recommend attempting ungluing the OLED as more often than not you just end up killing it. It’s better to get the full assembly.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Buy a complete screen assembly, they aren't cheap. If you don't want to spend a lot then I'd bang it on ebay as spares or repairs and let someone else have a go. OR, look on ebay for the same watch locked to icloud and use the screen off it.
Puan 0
Yorum Ekle
Yanıtını ekle
Stanley Bunch sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 865
