Ana içeriğe geç
Repair guides and support for the C650 series of Satellite laptops by Toshiba.
20 Soru Tümünü görüntüle
How do I reset my BIOS password on my Toshiba laptop?
I have a Toshiba Satellite C655D-S5136. I forgot my BIOS password and need to reset it. I already tried removing the CMOS battery, but it still won't let me reset my password.
Please let me know what I should try next. Is there something I should try to look for on the motherboard? If you could show me with pictures, that would be great.
Please help me!
Thanks
Bu iyi bir soru mu?
Puan 61
14 Yorum
naz, if I remember right, the password is stored on an IC and cannot easily be restored
tarafından
Jump D500 with copper wire. Tested, confirmed working with even new Windows 8 satellite c55t touch screen. If you dont have soldier iron scratch points a little, jump them, power cycle it. Done
tarafından
Heres a good bios password cracker than works guys! and its cheap!
http://www.bios-passcrack.org
tarafından
download a password remover
tarafından
9 tane daha yorum göster
Yorum Ekle
10 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here is a link to a number of solutions to your problem. Good luck.
http://www.technibble.com/how-to-bypass-...
Bu yanıt yardımcı oldu mu?
Puan 14
7 Yorum:
i have a toshiba portege and it is locked in bios how do i reset it
tarafından
I did this and now laptop turns on but black screen.....?????help
tarafından
Waste of time. Does NOT work
tarafından
how can i enter password for toshibagmfg550
tarafından
2 tane daha yorum göster
Yorum Ekle
I have a toshiba c655d-s5518, on that computer there is a jumper labeled xxx just above the DDR3 memory modules (towards battery), if you short the jumper while powering on it clears the BIOS password. on Some other C655D the jumper is labeled B500.
Puan 12
11 Yorum:
this worked great i found it and jumped acrossed it and it cleared and worked
tarafından
How do u short the jumper?
tarafından
D500 located next to RAM socket, confirmed working. Used this method on new windows 8.1 Toshiba satellite c55t. Calles toshiba wanted $220 to ship it out and replace to IC. What a scam!
tarafından
the toshiba password is SET
tarafından
the supervisor if you come across that is CLEAR
tarafından
6 tane daha yorum göster
Yorum Ekle
Some boards have a cmos reset next to the memory slot.
This has always worked for me across different brands...the "code" is the code you get when you enter the bios password wrong 3 times.
http://bios-pw.org/
Puan 3
3 Yorum:
i have toshiba l750 bios password how to remove
tarafından
ihave toshiba satelitte l35-s2151 which is da jumper da needs ti be jumped on this model please help it doesnt give me code after 3rd try just shuts down
tarafından
Hello' please help, My brother gave me his old laptop model Toshiba Satellite L780D and he already forgot the password, which jumper I need to jump for this model? many thanks
tarafından
Yorum Ekle
Don't Forget to remove element called "jumper".
Even if you remove cmos battery if don't remove jumper bios will not forget password
Puan 2
Yorum Ekle
there are 2 pins next to either the ram or the cmos battery. mine was next to the ram. youll see them next to the ram all alone. turn the computer off. take a flathead scredriver and touch the two pins. hold it there while you power on the computer. the computer should turn on and then shut down. now power it on normally and the password should be gone. ive done this in a dozen c655 and c855s
Puan 1
Yorum Ekle
For Toshiba Satellite NB15t:
To reset Bios password follow these steps:
1. take out memory stick.
2. on the system board (under memory stick) you see Jumper JRST.
3. by a small cable connect Jumper JRST to Ground (usually on the side of slot for Memory Stick)
4. push the power button to turn on laptop.
5. it will reset the Bios password
6. You are done. :-)
Kamran
kamran90@hotmail.com
Puan 0
2 Yorum:
Do you have an idea how to reset bios password for satellite L875D-S7230
tarafından
thanks for the info
tarafından
Yorum Ekle
1. Disconnect everything from your desktop tower.
2. Press the power button after unplugging the computer.
3. Remove the screws on the back to access the inside of the case.
4. Ground yourself.
5. Locate the BIOS reset jumper.
6. Move the jumper one pin over.
7. Wait about thirty seconds.
8. Return the jumper to its original location.
9. Close up your computer and reconnect any cables.
10. Power on the computer and enter the BIOS.
Puan 0
Yorum Ekle
pull out the bios ic name with winbond with 8 pins put it in the programmer download the bios file from toshiba webste extract the file there will be file with extension rom or bin try to make me picture i will guide you then programme the ic it will be claire i am very familiar with this
Puan 0
Yorum Ekle
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
https://www.iseepassword.com/forgot-bios...
Puan 0
Yorum Ekle
1. Switch on the notebook, when the boot logo appears press [F2].
 “Password='     will be display.
2. Press keys in the order [CTRL],  [TAB],  [CTRL]  and  [ENTER].
The Serial number and Challenge code will be displayed.
Please Note:
For some reasons it could happen that no PC Serial No. and Challenge Code will displayed instead of "Not Certified" appears. In this case remove the AC-adapter and the battery for a short time and try it again.
3. ''Please make the payment below or contact me
      My Skype : haisung4344
VERY IMPORTANT
Do not power off the computer once you provide us with a Response code. There’s a unique Response code .
Don’t turn off your notebook,  don’t restart it, don’t enter anything except generated Response code.
Puan 0
Yorum Ekle
Yanıtını ekle
naz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 122
Son 30 gün: 454
Her zaman: 364,351
