Ana içeriğe geç
A television game console produced by Sony Computer Entertainment; the PlayStation 4 Slim (CUH-2000 Series) is a thinner replacement model for the original PS4. Announced September 7, 2016.
Hdmi port replacement ps4 slim
Can a hdmi port from a pc motherboard work. If not, why?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It could work. Only if the port from your pc is the same as your broken ps4 port. The best way to find out is simply to compare them to each other. It is far from perfect though. Would highly recommend buying a new port for your ps4. Only a couple of bucks in China.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
To add in here just for clarity’s sake. Even though HDMI ports look the same on the outside, the arrangement of where the pins are to connect to the motherboard is not always the same. And there are different HDMI standards that use the same connector.
You’ll want to make sure any port you’re considering using is the same form factor as the one in the PS5. Even the ports between the PS4 and PS5 are not identical.
tarafından
Yorum Ekle
I think the best way to answer why not is to consider PS4 fat HDMI ports compared to PS4 Slim/Pro HDMI ports: They're upside down/backwards!
Luckily, a Slim HDMI port costs less than $10, so the question is moot. Just use the right part. Oh and on Slims, white light no display is almost never the port anyways.
Puan 1
Yorum Ekle
Yanıtını ekle
Roy Charles XPA sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 424
