Ana içeriğe geç
Toshiba Satellite L50D-B, Satellite bilgisayar serisinin bir parçası olarak satılan bir dizüstü bilgisayardır.
How to remove the internal SSD?
The internal SSD is not using the normal SATA connection, I have the backplate off. There are rubber corners around the SSD too.
Update (05/28/23)
Resim
. Photo
Bu iyi bir soru mu?
Puan 0
1 Yorum
I added a photo but I am unsure if it posted.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You should be able to just slide it out as shown in the attached picture. After you pull it out, you may find that the drive really is a SATA drive, just connected in a wonky connector. I was taking apart a laptop the other day that had a ribbon cable attached to an adapter that attached to a SATA connector on the drive. Just give it a go and let us know how it goes.
Good luck!
Resim
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
That works thanks!
tarafından
You're very welcome! I'm glad my tinkering was able to help someone! :)
tarafından
Yorum Ekle
Yanıtını ekle
SaltyAsterisk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 420
