Why does my screen dim as soon as it opens?
As soon as screen opens, it is normally bright for about a second, then dims and stays dim. Brightness is set to maximum. Have been told problem is either an "inverter" (?) or my screen, which will be quite costly to fix. Will the screen eventually go black, or get darker and darker? Is it fixable? Mac repair shop said they couldn't test "inverter" (?) because they didn't have the part in stock and said they couldn't tell me the cause of the problem. Machine is a PowerPC G5.
Bu iyi bir soru mu?
5 Yorum
Please give us the last three figures of your serial number so we can identify which machine you have and get you to the correct guides. Thanks
mayer tarafından
Marie, telling me that it a PowerPC G5 only partly tells me what the processor is. To help you I need that serial number.
mayer tarafından
W8548VVSTAR is the number.
MarieB tarafından
Apple iMac G5/2.1 20-Inch (iSight) Specs
Identifiers: iSight - MA064LL/A - PowerMac12,1 - A1145 - 2082
mayer tarafından
Thank you for the tip, will follow up.
MarieB tarafından
