Ana içeriğe geç
Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
How to identify the faulty part on the logic board
I got a macbook2017 that will not turn on.
When I connect the power, there is no boot/charge sound and no screen output.
However, the trackpad can be pressed.
I disconnected only the logic board, connected the power supply, and measured the voltage and current, which is around 14.7V and 0.4A.
When left as is after connection, the temperature is rising rapidly.
Since the macbook2016, which is operating normally, was showing around 14.7V, 0.1A, we suspect an overcurrent due to the failure of a component on the logic board.
(First of all, I would appreciate it if you could point out any errors in my discussion at this point.)
I would like to identify the cause of the problem in order to recover from the above.
I can't see any burnt parts as far as I can see with a microscope.
Therefore, I am trying to identify the short-circuited parts using openboardview and a tester, but there are so many parts that I am at a loss as to where to start.
I would appreciate it if you could tell me the best way to identify the components on the logic board that are suspected to be faulty.
Also, if there are other possible causes, such as degradation of the thermal paste in the CPU, that would be helpful as well.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
on the schematics search for the power aliases page, it will give you a list of the power rails to check
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Thank you for your response.
I am very glad you replied.
I checked the following.
* https://www.alisaler.com/apple-a1534-820...
I understood that page 61 of the PDF which I can get from here is the power aliases page you are referring to.
You told me that "power rails" is the point I should check, but I understand that the "POWRE RAILS" you are referring to are "G3HOT RAILS", "5V RAILS", "3.3V RAILS", "1.8 V RAILS", and "1.2V RAILS" are applicable?
I understood that if I search for these "RAILS" in BOARD VIEW, the parts to be inspected will become clear.
tarafından
@morison yes check all those rails, using openboardview with the board view file you can actually search for the power rail and it will show all components on that rail
tarafından
@daniel
Thanks for the immediate response.
Okay, I will follow your advice and have it tested.
tarafından
Yorum Ekle
Yanıtını ekle
Morison sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 169
