Ana içeriğe geç
Hover 1 Alpha folding E Scooter repair manual
9 Soru Tümünü görüntüle
How to remove/reinstall the rear tire on a Hover-1 Alpha folding scoot
The alpha has a motoring the rear wheel. Repairing a flat in the back tire is a ridiculously difficult task. Reassembley instructions would be very helpful.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Here's a video on how to do it:
https://www.youtube.com/watch?v=aML9BBod...
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Nope, that video is not for the Alpha. The Alpha has the motor in the rear wheel and many more spacers and washers it the axle
tarafından
Yorum Ekle
You need, large tyre levers (3), washing up liquid and two people. I take it you have removed the motor from the wheel.
Put the tyre and tube on the wheel. Spread the washing up liquid around the side of the tyre and push as much onto the wheel as you can. Whilst holding that in place have another person start feeding the tyre on with the tyre levers. When near completion you have to use brute force to get the last bit on.
Replaced loads at work so hopefully this will help you. Don’t use pushbike levers as you don’t get enough leverage, you need ones at least 12 inches long. Try not to pinch the tube.
Puan 1
1 Yorum:
Thanks this helps with how to replace the tube. I was also interested in how to reassemble the rear wheel to the frame. I'm not sure which side the spacer washer is installed on.
tarafından
Yorum Ekle
Hover support sent my a PDF showing how to remove the rear wheel. Thus should be all I need to reinstall it as well.
Puan 0
2 Yorum:
Can you send me said pdf mjtdrb@gmail.com
tarafından
Would you possibly be able to share the PDF?
tarafından
Yorum Ekle
Yanıtını ekle
sfaheysd sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 18
Son 30 gün: 42
Her zaman: 1,462
