Ana içeriğe geç
The HP Laserjet Pro 200 Color MFP can be identified by its model number: CF145A. This wireless-enabled color multi-function printer provides ePrint, touchscreen access to apps, and versatile scan, fax, and copy options.
Why are papers printing with "smudges" on both sides?
Every page is printing with "smudges" on both sides from top to bottom. While comparing multiple papers, I noticed the smudges appear to look the same and appear in the same location from paper to paper. So far, I've removed the cartridge tray and gently cleaned along the edges of the transfer bed. I have also inspected the toner cartridges and I noticed that some yellow (last/4th cartridge) is showing on the edges of the pink toner roller (3rd cartridge).
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Laser printers use static to transfer the toner partials from the drum to the paper, this is done by applying a charge via a wire near the drum we call it a chromatron. This wire can get dirty effecting the effectiveness of the transfer causing the smudge effect.
You need to clean and the drum as some toner has built up on it along the edge.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thanks Dan! Unfortunately, I ultimately concluded that it was a bad fuser.
tarafından
Yorum Ekle
Yanıtını ekle
Nick H sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 221
