Can the computer program be reset?
I have a Kenmore bread machine, the computer needs to be re-programmed.
Update 6/9/23
It's a Kenmore; model 6G22, I think?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
It can likely be reset by following the instructions below. Most of the bread machines I have used follow the same sort of reset process. If you provide the brand and the model you have I can research the correct reset method. This information will also come with the instruction booklet that came with your machine. If you have that handy.
Press and hold the Stop/Start button for ten seconds to cancel the program. If this is ineffective turn the bread maker off at the power for twenty minutes and the bread maker will reset.
I hope this helps.
Monte
Bu yanıt yardımcı oldu mu?
It's a Kenmore; model 6G22, I think? Looked in the manual I got, didn't see any help there. Will try your solution in the morning. Thanks.
Thanks so much for getting me out of that dilemma! It worked.... Very grateful!
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 51
Her zaman: 1,589
4 Yorum
@janetschuroll what exact model is your Bread Maker? What happened to it that makes you think it needs to be reprogrammed?
oldturkey03 tarafından Paylaş
When I turn it on, it starts in the middle of the mixing cycle.
Janet Schuroll tarafından Paylaş
I have the same issue with my Gorenje bm1600wg bread maker.
The 15 and 16 manual programs are failed to operate. After selecting one of them it's skipped to the next program.
I need a hard reset method for this machine. Pls help me!
Lusi tarafından Paylaş
