Ana içeriğe geç
2021 yılında piyasaya sürülen Dell Inspiron 16-7610 dizüstü bilgisayar için onarım bilgileri. Inspiron 16 Plus 7610 olarak da bilinir.
Possible to replace integrated webcam?
I suddenly started having issues with my internal webcam. All of a sudden it started being really blurry. I've tried cleaning the lens, but it does not work. I'm thinking perhaps a seal cracked and now moisture has gotten in there. Is it possible to replace just the internal webcam? Or do I need to replace entire screen to fix this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@zak18311 you did not give us your laptops model number but selected the Dell Inspiron 16-7610. You can download teh service manual for that computer from here Looks like that model has the camera integrated into the display assembly (the bezel around it actually). the camera is available as a spare part here for example. So that means you could try and use some heat to soften the glue that the screen into the assembly. Probably not an easy task and might be risking breaking the display, but nothing wrong with trying.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Dell probably uses snaps on these, that's the best case though. If not, it's clips and (hopefully) weak adhesive.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Zak sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 897
