Fix the hold close part
Part that holds it close broke
Bu iyi bir soru mu?
I’d first check whether the plastic tab itself broke or if the small spring/hinge piece just came loose.
If the tab is actually broken, the easiest repair is usually replacing the housing/locking mechanism, since gluing a stressed plastic latch often won’t hold for long. As a temporary fix, you could use a small piece of epoxy to rebuild the broken tab, but keep it away from the heated plates and moving hinge.
A photo of the broken area would make it much easier to tell what part is missing and whether it can be repaired.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 5
Son 7 gün: 9
Son 30 gün: 19
Her zaman: 248
@amander post some good pictures of what is broken etc. so we can see what you see. Edit your question and use this guide Mevcut bir soruya görsel ekleme
oldturkey03 tarafından
Mera Remington stairtinger garm nhi ho raha
Mishal Liaqat Bhatti tarafından
